Minstadave said:They do not know, there is no way of knowing (unless you melt a CPU or something, then they're unlikely to replace it).
Dolph said:Actually, you can normally tell if a CPU has been over-volted, even if it's not done any damage to the way a processor functions, if you can be bothered to examine it with an electron microscope... Which most manufacturers can't because it's a waste of time.
Slap said:Thanks guys; I was just curious to know when people overclock there chips how it might affect there warranties because manufacturers state that any overclocking will void it.
Would the same thing apply to graphics cards (no way of knowing apart from using an electron microscope) ? Or would the on-board memory act as a sort of black box/user history?
Those cold winter nights must just fly byMinstadave said:picked up a really geeky book all about the history of Intel from a second hand bookstore the other day though, which is quite enlightening.
Slap said:Curious to know how they know
ted34 said:As far as i know for a cpu you cant tell and with gpu unless you leave the mods on it on conductive paint trails they wont know either. With ram though they can tell if its been overclocked and i know corsair do check their ram. They cant actually tell its been overclocked but they can tell if you have put higher than standard volts through it. There is apparently a little component built into the sticks that burns out if the volts are over a certain amount. Have only heard once though of corsair returning a set of sticks saying that excess volts have been applied and warranty void
trojan698 said:Geil obviously dont do this, having successfully RMA'd my BH after putting 4v through it..
*EDIT*Minstadave said:Its summer here in NZ![]()
