Out of desperation I have decided to post in every single section of this forum, with a bit of luck either someone will have some information OR overclockers will bother replying to my messages or phone calls.
I bought the system (all built by Overclockers) in July last year. The system has been working perfectly until few weeks ago when suddenly, for no reason (no software upgrade, no hardware upgrade, no moving of the box) the system purely and simply hanged and never came back.
So actually what is happening:
1) turn ON
2) electricity seems to reach all components, the 3 fans starts, the POST indication 0.1, then 8.3 and get stuck at 9.9
then
3) less than 5 secondes after that everything shut down (all fans stops) and the machine tries to start again (POST restart at 8.3 etc.)
4) The system will continue looping for ever unless I turn OFF the complete power.
*** nothing ever appear on screen as there is not sufficient time for the power to start any components ***
What did I do to check/test?
1) remove the memory one by one and do the test again, try them all independently (in case one was faulty), but none of that changes anything. Actually even without any RAM, the system does the same thing!
2) checked every single connection of every component. No change
3) unplug some of the components to test (hard disk first, no change, graphic card, no change etc.)
4) CMOS reset (change the jumpers back and forth). That's where it is more interesting:
if in position 2-3: then same problem
if in position 1-2: as expected message CC (CMOS clear) so need to change the jumpers back to try starting
if no jumper at all: then all fans etc. starts but nothing is displayed on screen and nothing much more than fans running seems to happen
I have tried to raise RMA (never any response)
I have tried to call the various numbers and manage to talk to one non technical asking me to call the technical! and get a RMA before sending back anything...
I really don't know what to do, I cannot confirm which component is faulty but there is certainly one.
PLEASE HELP!!!!
Even if I need to pay to get that fixed by Overclockers I am ok, as long as that WORKS again!
Please transmit to their team if you have better luck than me.
Regards
Raphael
1) turn ON
then
PLEASE HELP!!!!
Regards
Raphael
