How do I add extras not on build option list
2 May 2011
Hi,
After MUCH deliberation I have pretty much decided on this system
http://www.overclockers.co.uk/showproduct.php?prodid=CA-167-AN&tool=3&groupid=2362&catid=160&subcat=
with a HIS 7950 iceq boost 3gb upgrade
I have another exact same 7950 which I want to add for Xfire.
I think I need to upgrade to a higher rated PSU , say 800 watt? will that do?
Also want to add a colour scheme, with some fan lights and led.
How do I go about the extras?
I emailed OCUK earlier, but no reply yet.
Also, could you reccomend a 24 or 27" monitor to do it justice. Around £250 max is my budget.
My main use will be Gaming, fps, bf4, Rome total war2, War Thunder, etc
Hope you can help, and thanks
Barry
That system... Being a case? :p
I dont think you are going to be doing much with a case, a graphics card and a power supply. :rolleyes:
What is your budget, are you willing to build it yourself or else learn how to build it yourself? And what do you want to do with it? :)
