How do I add remote central locking to my corsa
17 Jan 2006
NW
Ive got a corsa 1.4i breeze (r reg). it has central locking and wondered if its possible to fit a remote central locking unit to it.
I wouldnt mind electric windows either but think that would be out of the question.
Do you know how to do it, where to get the parts or how much it would cost to do the remote central locking
thanks
You can get remote locking kits for £25 off the bay but good luck fitting them, you really need to take it to a proper place, should cost around £125 fully installed.
As for the electric windows, yep thats possible and for a DIY home job might be easier, grab some door cards off another corsa with electric windows swap your current manual system for the electric system, would take a while to do but shouldn't be 'that' taxing.
Firestar_3x said:
.... but good luck fitting them, you really need to take it to a proper place, ...
Shush you, they are a doddle to fit, should take you a whole afternoon to fit.
Lol, Usually you get a bunch-o-wires a black box and instructions in some foreign dialect.
heh, that's the same remote that came with my alarm!
the central locking kit i fit to wifeys clio had no written instructions at all, just one big diagram with the colours marked for each wire, even i couldn't screw it up.
