Consigliere
- 12 Jun 2004
- SW17
Can't work it out...do i just pull at it slightly and hook it into a nail? Just doesn't seem like that would keep secure?
Yes, you pull it out slightly, put a pin head nail in the wall and it will sit in one of the grooves![]()
The part with the "teeth" yes?
Just tried to use a bit of force with it and see what you mean..thanks!
Also, any ideas about securing 91 x 61 cm wooden frames without nails? I think the wall is too thin to put a nail in it.
Too thin to use a nail? So is it plasterboard? If so, use some of these:
http://www.twsplastics.co.uk/store/index.php/metal-speed-plug-plasterboard-fixing-inc-screw-each.html?gclid=CNiqkJnI47gCFTMQtAodqwQAxQ
plasterboard fixings?
Gripfill, will stick anything, or plasterboard fixings.
Eek, and there is just one of those?The frame weighs 3.5Kg if that makes any difference...?
Yeah, they wont take that weight.
...To Poundland, get a set of screw in picture hangers.
