I like to keep my recycle bin full because on numerous occasions I have needed to get back a deleted item.
Thanks for the explanation. Seems it's not possible ,I'll just have to use the extra hdd as my public hard drive.Adding an item to recycle bin simply flags the file as deleted, and leaves the file in place, then empty the bin removes the flag meaning the file is deleted.
At no stage is a file actually moved anywhere.
Constraints on size are set per drive, and simply related to housekeeping actions.
You can't tell the OS to copy the file elsewhere when it 'deletes' it.
For this you've be best dragging (moving rather than copy) all files to a big folder marked deleted on your empty drive, and leaving them there. It would have the effect you want, but isn't a simple right click.
I'm not thank you. I have my own solutions for backup that have worked for decades.Then don't delete them. Absolutely DO NOT use your recycle bin as a temporary storage measure, it will only lead to tears.
What working backup solutions have you used for decades?
If you have a great backup solution then this shouldn't be important, and it shouldn't matter if you delete something you don't mean to.
I'd recommend that you look at realtime continuous backup software. You say you wouldn't mind file being copied about when deleting, well this will be similar. It keeps track of file changes so you can recover anything you delete or change. Acronis's nonstop backup is one I've used myself.
