23 Jun 2020 at 17:44 #1 DJai DJai Associate Joined 5 Apr 2020 Posts 308 I've had this in the house for a while and want to check if there is a disc in it without having the right power cable.
23 Jun 2020 at 17:46 #2 bremen1874 bremen1874 Soldato Joined 20 Oct 2008 Posts 12,082 There's often a small hole on the front where you can insert a straightened out paper clip to pop it open.
23 Jun 2020 at 18:09 #3 DJai DJai Associate OP Joined 5 Apr 2020 Posts 308 bremen1874 said: There's often a small hole on the front where you can insert a straightened out paper clip to pop it open. Click to expand... Thanks for your reply. I had tried pushing a pin in before posting and pushed hard but it didn't do anything.
23 Jun 2020 at 18:14 #4 drakulton drakulton Soldato Joined 20 Apr 2015 Posts 4,995 Location . DJai said: Thanks for your reply. I had tried pushing a pin in before posting and pushed hard but it didn't do anything. Click to expand... It needs to be quite long, say 25mm.and you have to have the pin dead straight as it goes in.
23 Jun 2020 at 18:15 #5 DJai DJai Associate OP Joined 5 Apr 2020 Posts 308 Ah, tried a tiny drill bit and pushed hard whilst jiggling and it worked. Much stronger and doesn't bend. There was a minions DVD in it! Thanks.
