How do i check if there is power
12 Jun 2005
Hi there,
I need to check whether my logitech mx1000 mouse power supply is supplying power.
I have a multimeter but i havent a aclue which setting it sould be on.
The output of the power supply is rates at +8B 500mA.
what setting should i have the multimeter on?
Thanks.
shadowze said:
You should set your meter to DC Volts
Symbol is a flat line at top , 3 dots below with a V below that
Ok i see that i have a few different settings.
Should i set it to 200m,2,20,200 or 1000
Im guessing either 2 or 20 but i dont know which one?
