How do I check...
19 Jun 2009
What clock speed my memory is running at?...
Sorry if this is a basic question, but in Easytune 6 it is showing as 1066 when its rated at 1600...
I've looked at the apps on this board, but none of them seem to run on Vista 64bit....
Thanks - I'm assuming that in CPU-Z, in the memory tab, the DRAM frequency is the actual speed that the memory is operating in?
If so, I have a major issue - It's showing 799Mhz... :mad:
Double the frequency, as above. DDR = double data rate.
That would mean your RAM is running at 1600mhz.
Hmm... Thanks again...
Still don't know why Easytune 6 was showing it as 1066 - I had to up it to 1596 myself manually... I updated the BIOS this morning to F7... Do you think this may have knocked the memory settings off?
At least it is running at the appropriate speed now...
