How Do I Choose a M/B for my Upgrade?
19 May 2004
Horsham, West Sussex
I plan to upgrade my PC. My budget is £300 although I accept I may have to go a little over.
This is what I want
CPU > Athlon 64 Venice 3000 or 3200 (Socket 939)
Heatsink > Arctic 64 Freezer Pro
Video Card > Radeon X1800 XT (or GTO if it can be flashed)
M/B > ????
Absolutely no idea about motherboards. My current is an ABit NF7 which I am pleased with but even if I just limit my choice to Abit there are 8 Socket 939 models to choose from. And it doesn't have to be Abit so this just leaves me with a bewildering choice.
I'm not interested in the following
- Dual Video Card
- RAID
- On Board Graphics
- On Board Sound
I'm interested in the following
- PCI-Express
- CPU Overclocking
- Possibly being able to add a better processor later
I guess once I've bought the other bits I have £50~£70 for a M/B but just from the Overclockers webstore this leaves me with almost 20 to choose from.
Help - there's too much selection!!
Cheers,
Nigel
how about ASUS A8N-E nforce4 ultra for £64.57, abit KN8 nforce4 ultra at £61.04 or MSI K8N platinum nforce4 ultra for £76.32. had the MSI was brilliant but wanted SLI so, but i would highly recommend the MSI if that appeals
Another vote for the MSI, using it in my set up and is soild as a rock and has good overclocking potential - got my 3700sd up to 2.85gb. Cant fault the board at all.
Thanks for the suggestions ...
What are the advantages of Geforce4 Ultra over plain Geforce4 ?
What are the benefits of the MSI board ? When I read the blurb the big selling point is Crossfire which I don't need as I don't want two GPUs. I'm concerned that Crossfire is where the money has gone or it is an older board - for example it has SATA 1.0 whereas, the other recommendations have SATA 2.0.
Cheers,
Nigel
Cheers,
Nigel
Think your looking at the wrong MSI board. The one I recommend is the Neo4 Platinum that can be found in the clearance section HERE (4th one down)
Its a high spec'd board and mine handles anything I can through at it.
Full spec for this board can be found HERE
