How Do I Clean The Plastic Window ?
17 Feb 2009
Every time I clean it leaves this horrible smudge marks.... I do have some window/glass cleaner, would that suffice with a re usable kitchen cloth ?
Would window/glass cleaner and a microfibre cloth do the job?
I can't see why that would be a problem, unless it's some branded stuff with loads of extra special ingredients.
Avoid anything with ammonia in, as that will cause damage.
If you have loads of bad scratches, you can buff them out with a very fine buffing wheel on a drill/Dremel™.
If it’s plastic it’s probably scratching extremely finely. You could use an automotive polish on it, that’s what I did with some of my retro cases plexiglass on them. Works well.
