I have been using 2 x 470's with 3 BenQ monitors, which only have DVI and VGA inputs. Not a problem as the 470's have 2 x DVI outputs each.
I have just bought 2 x MSI 7950's, which have 1 x DVI, 1 x HDMI and 2 x mini DP.
Now to preempt the problem of only having 1 DVI output, I bought a HDMI to DVI converter, but as always things are never that easy, the HDMI-DVI converter wont slot in when I have a lead plugged into the DVI slot, there is not enough gap between the two...doh!
So, what is my easiest solution to connect a second output on the 1 card to a DVI only monitor?
so I have time to get the bits in I need while I RMA one of these.
