How do I connect my Cisco Router to Our Netgear Switch
26 Dec 2011
Leicester
Hi guys,
Sorry for the dump question, bought some network stuff for work and checked I could connect the Netgear switch to the Cisco router via ethernet and was not yes this is normal - however there is no clear (clear enough for me) connection point?
Here are the products:
Netgear - GS724TS
Cisco - 2921/K9 V07
Thanks guys!
Connect a Cat5e cable from one of the Gigabit ports on the router to any port on the switch. Then do a no shut on the interface within iOS.
Sorted cheers guys. Switch automatically knew it was an internet connection so I did practically nothing other than connect it all up!
Just to require all the offices now ready for fibre launch tomorrow!
Cheers
