How do i connect my Xbox 360 to my PC?
26 Oct 2006
London
hey guys, for the past couple of weeks i've been using my xbox 360 on my Hyundai 19" monitor along with my 5.1 speakers, but everytime when i need to use my xbox, i need to disconnect my speaker cable from my computer and connect it to the audio input on my xbox vga cable.
I know this sounds very straightfoward, but its actually very daunting because the audio connector on my vga cablei s very short and its at a distance from my speaker cable, and there are also a excessive amount of cables and wires at the back so its pretty frustrating to move between one cable to another.
I know its possible to connect your xbox 360 to your PC but i can't seem to figure how thats done, do i need some sort of hardware inorder for me to connect it to my PC?
I also wanted to ask another thing, whats the best resolution to have for my 19" monitor in the xbox settings menu.
Theres a new settings which mincrosoft recently added in the settings menu which lets you enhance the picture quality, at the moent i have it to expanded, is that good or should i put it back to standard?
would appreciate any advice.
Use the 2xRCA to 1 3.5mm phono jack that comes with the VGA cable (The grey triangle adapter) and plug it into your PCs line in port.
What's the native resolution of your monitor?
