- 1 Dec 2003
i've had the x360 now for a month and have decided to try out the live arena.
i want to share my internet connection with the PC. i had a go at using internet connection sharing but this didnt work
. i was trying the onbard ethernet connection on my mobo? does anyone connect this way? is there a checklist of what i should be doing?
failing that whats the best way to connect, a router or wireless. the pc and xbox are in the same room.
ta
. i was trying the onbard ethernet connection on my mobo? does anyone connect this way? is there a checklist of what i should be doing?failing that whats the best way to connect, a router or wireless. the pc and xbox are in the same room.
ta
