How do I correctly configure DD-WRT router with a second Netgear router?
19 Jan 2003
Bristol, UK
Hi all,
My parents have the following setup:
Spare bedroom: Cable modem -> Netgear wired router with 4-port switch -> PC1
Office: Cable from Netgear 4-port switch -> DD-WRT (Buffalo Wireless router) -> PC2
Originally I had it all setup so the Netgear was the DHCP server and the Buffalo just acted as a WAP.
I have now had a play with DD-WRT to try and improve stability as they were often resetting things. I want the DD-WRT to act as the WAP and the DHCP server.
I have given the DD-WRT an IP of 192.168.1.1 and the Netgear 192.168.1.2.
I have switched off DHCP on the Netgear.
I inputted the Gateway and Local DNS on the DD-WRT as that of the Netgear's IP address 192.168.1.2.
I realise there network was a bit of an odd setup but it's the only way I could get the layout they wanted without running more cabling.
I am tempted to relocate the cable modem to the office though as that would do away with the requirement for the Netgear router which is also being used as a switch.
Is DD-WRT going to be much more stable? I was finding that it was the Netgear switch and WAP crashing independently from time to time so by switching off DHCP hopefully the Netgear will be more stable.
If I just used the Netgear as a pure switch would that work? Does the cable modem have to be connected directly to a router? Can I point the DD-WRT at the cable modem through the switch? Perhaps I am mis-understanding the roles of the hardware on my network?
Any recommendations appreciated.
You can plug the modem into a switch but its very fiddly to get working. Better off moving the modem if needed. I find DD-WRT pretty good but you can also get a Linksys WRT54G cheap which can run tomato, to save moving the modem.
