How do I create a custom resolution in ati catalyst
31 Jul 2009
Hi all.
I am trying to create a custom resolution for my monitor (1920x540) but in ati catalyst the minimum the width will go when creating a custom resolution is 720. Is there a way to get it even lower? Thanks
I was wondering the same myself as i have a cheapo tv for the bedroom with a vga that wont enable the stated res of 1440 x 900, the max I can get is 1024 x 768.
easiest way i found was go to desktops and display in ccc the at bottom right click on the screen click configure and then go to HDTV support then tick the 720p60 ntsc format and then apply, the one the resolutions are showing in the bottom tick one that within you monitors range from the bottom ones added then apply format and once they are applied it will highlight the add button which will then allow you to set you own custom res.
