How do i disable the speed throttle options on amd cpus
27 Sep 2009
i have a 890GPA UD 3G GIGABYTE BOARD with a 2.8 X6
Now i have disabled cool and quite and C1E but still cpuz shows 800 mhz. its when the cpu is under load that it hits 3.0ghz (ive ocd)
rest of rig
As above with:
1600mhz hyper x
akasa freedom tower
250gb hdd
samsung dvd-rw
stealth extreme 2 500w
thanks
whats wrong with turbo mode?
my 1055t cpu is stock now but i tested a quick oc changed to 220fsb and got 3.6ghz easy, on load it went to 3.6 and on idle it saved power, heat, noise and wear and went to 800mhz
on games it made no difference
