touch a radiator pipe/the case/dont work on carpet![]()
what dont stand on the carpet also just touching the metal panel on the case works.
what screwdriver would i need
If you're wear rubber soled shoes it's not so much of an issue. In either case you should touch a metal object such as a radiator to discharge any static charge you have built up before commencing work.
Your fine using a magnetic screwdriver. The magnets are not that strong.
