I don't know if there's a better way (i.e. someone knows the direct reg key) but in the absence of other replies so far...
Download THIS free trial. It will only give you the first 10 digits of the serial as it's a trial, but if you then search the registry for that string of digits your full serial should turn up in the appropriate key?
Worth a go![]()
Worth a go![]()
