How do I format external USB hard drive to FAT32 for PS3?
2 Mar 2009
Nottingham
I have to admit that I think this question sounds a bit silly, as it can't be that hard can it... well, I can't find a solution!
Windows 7 only allows the drive to be formatted as NTFS or exFAT, both of which are not recognised by the PS3.
Is there any way that I can do this within Windows 7, or can anyone recommend some basic freeware that would do the job for me?
I can format my 8GB USB memory stick as FAT32 and it works on the PS3, but I wanna put all of my movies onto my 320GB WD Passport external USB hard drive for convenience :rolleyes:
Thanks all!
Diskpart has NOT worked... :(
After a long wait, it had reached 20% so I just left it for a bit!
Now that I've come back, the message on screen is:
Virtual Disk Service Error:
The Volume Size Is Too Big.
Back to square 1. Any other ideas please?
Stand down - all sorted! Just downloaded Partition Master to my old XP netbook, and formatted the drive using that.
Working perfectly as intended on my PS3 with MP4 movie files - cheers all :D
