how do i get 1t on my asus a8v
30 Sep 2003
hi all.
just put 2 sticks of hynix 2x1gbsticks in my asus a8v rev2 bios 1013.
memory runs in dual channel slots at cas3 .4.4.8 2t
i cant find a 1t option in the bios
memory is running at 210Hz slightly clocked.
rig.
A64 3200 @210Ghz
memory as above as is mobo
Leadtek A400 6800 non ultra early edition at 357/755 12/6 pipes and shaders.
runs at 32deg idle and about 44 hard gaming on an xp120 and 120mm fan.
thanks in advance
Mike
i have had a look with no joy, here is what i have.with options.in the brackets are what is currently set.
MEMLOCK MODE (AUTO) OR LIMIT
SOFTWARE MEMORY HOLE (ENABLED) OR DISABLED
BANK INTERLEAVING (AUTO) OR ENABLED/DISABLED
BURST LENGTH (4 BEATS) OR 8/4/2
MCT TIMING MODE (MANUAL) OR AUTO - MANUAL GIVES ME OPTIONS
CAS (3) OR 2-2.5-3
TRAS (8) OR 5 TO 15
TRP (4) OR 2 TO 6
TRCD (4) OR 2 TO 6
TRRD (2T) OR 2 TO 4T
TRC (12T) OR 7-22T
TFRC (24T) OR 9-24T
TRWT (4CLK) OR 1-6CLK
TWCL (AUTO) OR 1-2CLK
TWR (AUTO) OR 2-3CLK
ASYNCLAT (AUTO) OR 4-9CLK
READ PREAMBLE SETTING (AUTO) OR 2-9ns
2T COMMAND (ENABLED) OR AUTO/ENABLED/DISABLED.
Thats bios 1013
Disable the 2T option, you only need this to run 4 dimms at dual channel. Disabled it will run at 1T as Mikey states.
You should be able to run 2-2-3-10 stable, however, put your settings in without an overclock to see if its stable then gradually overclock to see what it will take, ease timing if you want to take you overclock highwer, until you find your sweet spot.
