How do I get a tp-link ac1600 router to work with now tv
11 Aug 2019
I bought the tp-link AC1600 router as I read it will work with now tv but could someone tell me how to do I set it up to work. I have the username and password from wireshark but I don't know if it's correct.
Now TV is the same network as sky, so just follow this
https://kevq.uk/how-to-use-a-tp-link-router-with-sky-fibre-optic/
Sky don't even check the username/password anymore, just has to be the right format. So I assume nowtv doesn't either, but you can just use the username pass you extracted anyway.
