How do i get full speed with my wireless?
26 Apr 2008
York
Hi, i have a dgn2000 netgear router and my desktop has a wpn111 usb adapter however when im connected to the network the speed it is connected is 54Mbps as shown below:
The router is set up for b&g connections and the adapter should connect at 108Mbps, so why is it not using the fastest speed? DO i have to use the netgear wireless software?
Thanks
LOL, how did you find that? I tried to block all of them! Its a joke within our house and thought it mite offend some people so tried to edit it out! Obv not good enough! Ok thanks. I was using Wireless Station Access List so pretty secure! Does WPA2 support this?
edit: ah found the one which slipped thru!
i thought:
b - 54Mbps
g - 108Mbps
n - 270Mbps
Is that not right?
I know im not on n speeds, havnt bought an adaptor for this router yet.
