How do i get my 'Default' CPU voltage back?....
16 Jun 2004
Spec as in Sig.....
Default Volts on a 550 is 1.35v, but i tweaked it up to 1.42v when overclocking and has been perfectly stable but i want to see if it can run with a lower setting of 1.375 or 1.390, so i set the voltage accordingly using Easy Tune ( a gigabyte utility) within windows and CPUID records the new voltage as such.
But whenever i reboot or shutdown, the voltage is back to 1.42....:confused:
I've tried resetting the CMOS, but its just the same, in the BIOS, CPU voltage is set to AUTO which should set it back to 1.35, but again goes to 1.42v when in windows.....
Is there any way to get it back to its original setting of 1.35v on startup and work up from there?.
Also when i set the CPU to its stock speed of 3.1Ghz and CPU Volt control to 'Auto' in the BIOS, CPUID will still show 1.42v....arghhh!!!
