How do I get rid of a borked WU?
21 Jan 2005
Manchester
As the title says I have project 772 worth 149 points but for some reason it is taking an age to complete, can I delete this WU and get another as its telling me its going to take two weeks :eek:
If you really feel the need to get rid of it then just stop the client, nuke the work folder and restart the client.
Are you sure there is a problem and it's not just something to do with the GPU client [if you are running it] or something else nicking CPU time?
SiriusB
SiriusB
Hey Sirius, no I'm not running the GPU client on that machine and also I have the same WU on another similar machine that saying completion in a day and a half, must be borked.
SiriusB said:
Nuke it then. Tis only a tiny WU - Stanford might not notice :p
SiriusB
Thats weird, removed work file, recieved exactly the same WU but with a 2 days completion instead of 2 weeks. Result.
If monitoring with Fahmon it needs some checkpoints to actually work out the time it's going to take. Sometimes it just seems to put up a silly time rather than N/A. Also perhaps SSE didn't kick in assuming your using a CPU with SSE. :)
that would be my guess - restarting the client would have got SSE working again anyway
it's best to use the -forceasm flag to avoid things like this (caused by messy restarts/crashes) unless you're already using -forceasm in which case the WU may have got corrupted or something
9/10 of the time you get the exact same WU back anyway, so assuming you weren't about to finish no one really loses out from the nuking of a WU.
Stanford still get their WU results, just a little later and you still get the points, just a little time is lost.
SiriusB
forceasm is on all my machines, tried restarting didn't do anything, must have been a borked WU
Yep the server recognises your UserID and the MachineID tagged on the end so sends out the exact same WU you already had - kinda annoying at times but you can always change your MachineID to fool it into giving you something different :p :D
not that I'd ever dream of doing something like that of course :o
