Currently running:
Dual Core E5200 @ 3.6ghz
4 Gig Ram
GTX 480
600W Be Quiet! PSU
Gigabye G41M ES2L motherboard.
Just tested two cards a radeon 5850 and my gtx 480 - both cards get exactly the same FPS in Mafia 2 and Crysis benchmarks so it seems my cpu is limiting them both? How do I get rid of the CPU bottleneck all together? I want to do it as cheap as possible so would a cheap I5 or I3 and overclock it be the best option? Or is there a AMD cheaper alternative? Just for gaming needs and get rid of the CPU bottleneck. I'd get a Q6600 but I don't think it would make all that difference considering the E5200 is running at 3.6ghz so it maybe the same in some games which don't utilise 4 cores?
4 Gig Ram
GTX 480
600W Be Quiet! PSU
