How do i import my phone numbes from iphone to galaxy note
its the phone numbers im after
Google stores phone numbers in gmail contacts, that's what all Android phones use.
Not sure if you can export straight from the iPhone though, you'll probably need to use iTunes and export contacts to something like Outlook first.
I must admit, I've always resorted to typing them in but I only have 40-50 and I keep them typed up in a notepad doc just in case. Probably a way of doing it but by the time I'd invested 10 minutes into it, I'd have half of them on
What network are you on? If you're on Orange, they have a bundled app that backs up your contacts every month. Launch Orange Backup from the Android phone and it'll retrieve the contacts that it has backed up. Not sure about other networks, but I presume others have similar. If so, and you haven't run it yet, go back to your iOS phone, run it from there, then switch sims to the Android and run it again from there.
howdy :)
my previous post has worked fine for my 3GS, but my GF's 3G just isn't having it.. I choose to sync contacts to gmail in iTunes (using a different gmail account), iTunes does its thing, but the contacts never bloomin' show up in gmail! Works fine on my phone :p
Any other alternatives to copy contacts from an iPhone to import to gmail for an Android device?
Cheers!
*edit
Will try this:
http://www.trickyways.com/2010/06/how-to-export-iphone-contacts-as-csv-file-in-windows-7/
