how do i increase voltage of ram?
Typically in the BIOS. But there's some apps which allow you to do it in your OS, depending on your chipset.
If you're not sure of the voltage amount, use CPU-Z and flick to the memory tab, as this often gives you the voltage info you need.
ok thanks raised mine from 1066 to 1333 seems stable enough increased volts to 1.525 which was 1 below the red on my mother board :)
