How do i know if an XP key is home or professional?
26 Mar 2004
Got an old laptop with a corrupt windows.
So i want to reinstall windows and use the license key stuck on the laptop. unfortunately the bit where it says whether its home or professional edition is wiped off.
How do i know what version this laptop had?
boot from a linux bootable cd (slax is a good one to use, it's small too)
then open...
c:\windows\system32\eula.txt
scroll to the bottom of the file, will tell you if it's home or pro
it'll also tell you if it's an OEM or retail copy too (this is important...)
have a look at what the whole name is..
(sorry, could have said this before)
