How do I mount and executable on a CD?
Permabanned
19 Nov 2008
Peterborough, England
Basically I got a ripped driver CD but it wants the original CD in the drive to install so I thought i would burn the CD with the files I have as they are the same. I just need to know how to have an exe. as the image of the file. Thanks
not quite sure what the problem is..
are you saying you've got some exe files from a cd on your computer which you're trying to install, but the exe's want the cd in the drive?
If it's a manufacturer distributed driver CD you might be able to download the cd image or more suitable files from their website rather than use a 'ripped' version..
Basically you can download the latest drivers from the website but they won't install unless you have your original CD that came with the product for verification. I bought this TV second hand and it didn't come with the accessories.
