- 28 Oct 2011
They are MP3's by the way.
Add the MP3s to your iTunes library then sync that library with your iPhone.They are MP3's by the way.
Connect phone to computer with cable.There's no wifi syncing button on Itunes PC app?
It is supposed to be next to "music".
I have wifi turned on PC, have been able to inport mp3 to PC ap, but cannot connect PC app to Phone.
Just a lightning to USB. Your iPhone 13 should have come with one.Ok, I was trying to do it without buying one, what do I need?
Yeah try a lightning to USBA cable if your USBC port isn't working.Yeah it doesn't register with my PC, donlt think that USB (C?) port is working, I have the big USB's (A?) next to it that work?
oddly my windows 10 box stoppped recognising my iphone. It was using the version in the Microsoft store, and followed by about 4 mandatory patch cycles so at some time got messed up.Yeah it doesn't register with my PC, donlt think that USB (C?) port is working, I have the big USB's (A?) next to it that work?
