How do I overclock on an A8N32?!?
18 Oct 2002
London
I have an Asus A8N32-SLi and 3000+ and I haven't got a clue how to o/c my cpu...? :o
In my previous ABit + 1gz socket A chip I set my fsb to 133, and the multi to 10x.
Easy overclock. (133*10).
Now on this new board I'm really confused, there's so many options and nothing seems to do anything, or it just fails to POST.
I can't even work out how it's getting 1.8ghz, the numbers I see don't add up.
Is there a guide, or is it simple? Please help! :)
I'm sure the numbers do add up :p
CPU multi = 9x
FSB = 200
HTT multi = 5X
Memory devider = 1:1 (200mhz)
Set the HTT multi to 4x, memory to 166mhz and then raise the FSB testing as you go.
CPU multi = 9x
FSB = 200
HTT multi = 5X
Thanks, I couldn't find anything like HTT 5x?
I set the memory to 166, and moved the fsb to 220. I'm on 1980mhz now.
But If i move it to 221, it moves the multi to 8x and my cpu drops to like 1.7ghz?
Am I doing something wrong? :S
best thing to do is list the options you have and the sub options. then maybe we can help you.
i had that chip running at 300x9 on HTT x3 at 1.52v. :)
First off switch off Cool & Quiet as this automatically reduces the multiplier of your CPU
The HT Multiplier is sometimes called the Hyper Transport Speed. You'll have five options - 1GHz, 800MHz, 600MHz, 400MHz and 200MHz. This equates to 5x, 4x, 3x, 2x and 1x respectively. This is calculated by the HTT x HT Multiplier. You don't want it to go over 1GHz so reduce it to 4x first (up to 250MHz HTT, 3x to 333MHz, etc)
