- 7 Sep 2009
My friend has given me his ~5 year old pc to fix because it no longer turns on via the power button. I think he hadn't used it for a while and when he tried to, there was no response.
I've read the motherboard manual (Abit KN8 SLI) and all the correct LED's on the motherboard are on once the power is turned on at the wall. The LED for power from CPU is on.
I've tried touching the two pins that corrospond with the PWR_SW with a metal screwdriver but nothing happens. That is the advice I've found when using google. What could be the issue do you think?
ps. I've taken out the hdd's, the graphics card and the DVD drives. Could that have anything to do with it? It was impossible to get to the front panel connectors due to drives/cables and cable ties which is why I removed said components. As far as I'm aware though, the motherboard should still power on.
Thanks
Thanks
