How do I....(PS3 related).
Caporegime
4 Jul 2004
Put music, videos and pics on the PS3 from my PC :p :o? I'm only used to doing it with the PSP lol.
Also, the PS3 doesn't recognise my pro duo memory card. I push it in until it goes no further (it feels like I'm pushing it in too far), there's no click or anything?
Thanks.
Thanks.
Can't copy direct from the PC to the PS3 at the moment. You need to use a medium like PSP, memory stick or something in between.
My memory card just slots into the PS3 the same way as it does in my PSP. You should feel it spring into place.
rp2000
rp2000
Ahh thank you. Going to take a long time to transfer all my music then lol :(.
And the memory card, it just goes in and stops, no click or anything.
can a linux pc read the file system the PS3 uses?
I've not got a linux machine here (at my parents') and XP can't read the FS.
I was thinking you might be able to just plug the PS3 HD into your linux PC and stick the files on that way.
It's really easy to get the hard drive out.
