How do I quote multiple posts in one post?
8 Jun 2006
Hertfordshire
Hi guys
A lame question I know but I would like to know the fastest way of quoting different peoples posts in one post (if you get me) so I can answer mutiple comments in the same post?
Can anyone point me in the right direction please?
Many thanks
If i ever do it, it's usually i open up a few new windows using Ctrl-N (in i.e.7) then generate a quote in each new window from the original post (as it opens up on that page using ctrl-n) then just copy the text from the quick reply box into the original reply box in the window. Not sure if there is another way but seems to work for me.
[ QUOTE=gumbald;11048131 ][ QUOTE=tweakinfreak;11048126 ]
Hi guys
Many thanks[ /QUOTE ]
Copy and paste lots.[ /QUOTE ]
Hi guys
Many thanks
I click the quote button, ctrl+a the post then ctrl+x - rinse and repeat till I have everything, then construct in the last page or Notepad if its a few hundred words.
use firefox, middle click each quote, then ctrl + tab thorugh them copying & pasting as you go along :)
doesn't take long
