How do I remove fan connector.
Permabanned
8 Jan 2010
UK
Hi,
I installed some Scythe AP-15's and I would like to sleeve the ghastly looking wires. Is there a tool which I can use to remove the pins whilst preserving them to be re-used again. Or a special way to remove them without purchasing expensive tools?
If what I need is listed on a competitors website (If not stocked by OCUK) then could you PM me the link please?
Thanks
nvm some fine tweezers did the trick. Would 8mm braid be ideal for bunching the 3/4 fan wires together? Or should I go for something smaller or bigger?
Thanks
Well, individual wires are often done as 3-4mm braid, to my knowledge, so try and figure out how much you can fit into X mm of braid.
