How do i remove the Northbridge fan..
exs
exs
23 Dec 2005
I have a k8n neo2 platinum motherboard and my zalman heatsink has arrived.
I am unable to remove the fan ( it has two springy things each site attached to the motherboard, and they have no screw holes )
Thanks.
It doesn't use screws as such.
If you look at the underside of the motherboard you will see 2 black pins sticking through that have a cut in.
What you have to do is squeeze the slot / cut together, and push the pins through.
Use either tweezers or similar.
Once the pins are out, it may not fall off as MSI used some weird goop to hold it on with. (thermal compound)
Hairdryer is last resort to soften it.
