How do I see X1900XTX Temps
27 Jan 2006
Gloucester
Hi, just upgraded from 7800GTX to X1900XTX. I am using the drivers which came with card. How can I check the temperature of the card, is there a registry edit or something to add it to the CCC? Thanks.
I don't have an ATi card but i think ATi Tool will read the temps. You might have to search around for the latest version as the x1900's are new cards :)
it is in the CCC by standard -> ATI overdrive (where you do the overclocking) has a temp monitor on as well.
At least it does for the X1800XT :)
