How do I set Quake 3 for 1920x1080 res?
Nope it doesnt understand anything other than 4:3 resolutions - it was made in 1999 god damnit :p...
Quake Live will fix that :)
ps3ud0 :cool:
Fov is bigger and the game field itself is fine though...
Most games simply stretch the hud that's simply unavoidable, read the detailed report:
==HUD stretch==
The HUD stretches. Check out Sarge's fat face!
==Cut-scenes==
Since this is a multiplayer-oriented game, the cut-scenes won't be factored into the grade. Good thing for Quake 3 too, because they are completely broken.
==Grading==
Calculated grade: B
This wouldn't have been so high if Quake 3 had a serious singleplayer mode. Its support is good for things that are important to a multiplayer game, but not so good for the things that are only important to singleplayer games.
Major unresolved issues:
None.
Minor unresolved issues:
None.
Summary of widescreen-related flaws:
.ini solution.
Stretched HUD.
The game itself is fine though and not stretched.
You can use the ioQuake.exe file instead. That works with non-4:3 resolutions. It's massively improved over the original quake.exe actually, but doesn't work with punkbuster.
oops
i was hungover as hell this morning, and just overlooked those posts (even one's I'd done) without checking them again :o
thanks for the link mate, will try it out :)
edit, still not working..? :/
ok, i'm in the console.
following this..
"How do I set a non-standard resolution? Widescreen?
You’re in luck, not only do we have instructions for setting a non-standard resolution, but in Widescreen modes we’ll display Quake 3 more properly than id’s last version. So for my macbook, I’d set:
* r_mode -1
* r_customheight 800
* r_customwidth 1280
then if I’m in-game I would use vid_restart
Note that the in-game video preferences will not list your new resolution. This is normal."
i type
r_mode -1 (press enter)
r_customwidth 1920 (press enter)
r_customheight 1080 (press enter)
vid_restart (press enter)
sod all happens.......
windows 7 if that makes the slightest difference
