How do I set this up?
10 Jul 2006
I basically have the following fictional topology:
I have access to [Router 2] but not to [Router 1].
Currently, [Router 1] has a port forwarded to the IP [192.168.1.2].
[Router 1] has a static IP for the PC labeled [192.168.1.2] based on the MAC.
Now [Router 2] has been introduced. How do I still get the information to be forwarded to the [192.168.1.2] machine.
I hope that makes sense.
Thanks.
Why are you using two routers? You should really just be using a switch. Anyway, you can use the 2nd router simply as a switch - just don't plug anything into the WAN port on it and disable DHCP on it. It'll then simply act as a switch and get IPs via DHCP from the first router.
By WAN, I assume you mean the Internet port.
I am using two routers as i don't have a switch available.
Thanks.
EDIT:
Working Now....thanks!
