9 Jan 2007 at 14:09 #1 bogeyman bogeyman Associate Joined 24 Dec 2006 Posts 7 Or, more specifically, how do I show FPS during playing BF2142? I've seen others do it, I haven't got a clue, nothing in the menus etc... It must be a standalone piece of software, any advice?
9 Jan 2007 at 14:13 #2 GSDog GSDog Soldato Joined 12 Jun 2004 Posts 5,477 Location Exeter For BF2 you need to go into the command prompt and type "renderer.drawfps 1". I don't know if this is the same with BF2142, but worth a try.
9 Jan 2007 at 14:13 #3 DDave DDave Associate Joined 12 Dec 2003 Posts 929 Location Scotland renderer.drawfps 1 in the console I think.
9 Jan 2007 at 14:13 #4 DavidQ DavidQ Permabanned Joined 10 May 2006 Posts 1,190 Location Northern Ireland FRAPS can also display your fps, aswell as record footage from your game
9 Jan 2007 at 18:40 #6 Pint Pint Associate Joined 2 Aug 2006 Posts 59 If you have an ATI card then ATI Tray tools has an option to display the frame rate.
9 Jan 2007 at 19:11 #7 Deathwish Deathwish Soldato Joined 17 Oct 2002 Posts 2,956 Location Cold Scotland :( If you have an NV card then NVTray will do it also (via the OSD). Along with gpu temps etc.
9 Jan 2007 at 23:22 #8 Fr0dders Fr0dders Caporegime Joined 18 Oct 2002 Posts 33,472 Location West Yorks use a free download called fraps its a little tray app which sits in your system tray and provides a much clearer and bigger indication of fps the build in FPS counter in BF2 is tiny and in plain text, fraps is a much bigger yellow affair, much easier to read
