How do i start a program with a certain priority.
12 Jun 2005
Hi there,
How do I load a program so that it has a certain priority. Can you do it without using a batch file? If not, how do you do it usinga btach file.
Thanks.
Conrad11 said:
Hi there,
Thanks.
Code:
C:\Documents and Settings\Daz>start /?
Starts a separate window to run a specified program or command.
START ["title"] [/Dpath] [/I] [/MIN] [/MAX] [/SEPARATE | /SHARED]
      [/LOW | /NORMAL | /HIGH | /REALTIME | /ABOVENORMAL | /BELOWNORMAL]
      [/WAIT] [/B] [command/program]
      [parameters]
    "title"     Title to display in  window title bar.
    path        Starting directory
    B           Start application without creating a new window. The
                application has ^C handling ignored. Unless the application
                enables ^C processing, ^Break is the only way to interrupt
                the application
    I           The new environment will be the original environment passed
                to the cmd.exe and not the current environment.
    MIN         Start window minimized
    MAX         Start window maximized
    SEPARATE    Start 16-bit Windows program in separate memory space
    SHARED      Start 16-bit Windows program in shared memory space
    LOW         Start application in the IDLE priority class
    NORMAL      Start application in the NORMAL priority class
    HIGH        Start application in the HIGH priority class
    REALTIME    Start application in the REALTIME priority class
    ABOVENORMAL Start application in the ABOVENORMAL priority class
    BELOWNORMAL Start application in the BELOWNORMAL priority class
    WAIT        Start application and wait for it to terminate
Dont know of a way to do it otherwise, short of changing the priority after its started.
Ok thanks.....but I don't understand that in the slightest, could you explain, or even better give me an example?
Its by changing the property of the program. IIRC and I could be wrong you would put the desired prompt after the name in the property window of its Icon eg.
Game.exe /'Normal'
+44
