how do i stop my sons 360 from accessing my pc
23 Nov 2009
North Leicestershire
he keeps listening to my music and it's pretty annoying anyway i can stop this as we both share the same wirless network
his 360 just seems to be able to see my music no password etc etc are needed
pretty easy james
turn your comp on then switch on his xbox and in media player goto tools then library and sharing his xbox will be in there just highlight it then tick the block or deny button. had to set up both of mine to allow mine to access and the kids one not to .
pretty easy james
cheers bro all sorted now
or on the navigation pane there's a drop down men named 'Stream' drop it down and click on 'more streaming options' disable all those you dont want to share with
