How do I stop security alerts?
27 May 2009
I have just install vista64 ultimate and everytime I do something I get a security alert.
How do I disable these alerts?
I have norton internet security running.
You mean the User Account Control? I think it would be best to leave it on..to turn it off however,run MSconfig from the search bar in the start menu and go to 'tools' tab and turn it off there.
If you're referring to User Account Control then it's highly recommended that you leave it enabled.
Since you have just installed Windows Vista and going through that initial stage where you're setting up your system, you will get a number of prompts. However, after you have installed your applications and configured the system to your liking, the prompts will quieten down. If you're finding that you're still getting too many prompts to the point were it's getting annoying, then download a program called TweakUAC and set UAC to silent mode. This will eliminate the prompts whilst still protecting you to some degree.
