How do I stream my music over wifi with iTunes
13 Jan 2006
Wigan
Ive got my music library on my pc.
I want to be able to play it on my iPad or iPhone or MacBook or windows laptop over wifi
What do I need to do this?
I have the remote app on my iPad but that only seems to play the music thru the pc speakers and I can't see an option to switch it to iPad speaker.
Is it possible to do with iTunes.
Thx.
Ok I've got all iPhones and iPad controlling all pcs and laptops :p anything can be played on any laptop or pc.
But I only get my media to my phone/pad and her media to her phone but each pc and laptop can see and play both librarys.
The only think I can't do is stream to play both media librarys to an iPad or iPhone.
Can this be done?
Thx
II have the remote app on my iPad but that only seems to play the music thru the pc speakers and I can't see an option to switch it to iPad speaker.
I'm guessing you never read the app description as it can only be used to control iTunes and apple TV.
I think it's only possible to view your own iTunes library via Home Sharing on the iPhone/iPod/iPad and not anyone else's unfortunately.
I've sorted all that.
Ok thanks. No major problem but would have been nice to stream both our collections anywhere in the house.
I've enabled it and I can stream my library to my phone and my fiancées library to her phone but not her library to my phone and vice versa.
Are you absolutely sure you're not confusing Home Sharing with sharing your iTunes library? (whilst listed together in iTunes' preferences, they are separate features).
@utajoker, In this scenario you will need some sort of iTunes streaming server then.
Home Sharing
http://support.apple.com/kb/HT3819
You can't stream from iPad to iPhone for example. It will have to be from iTunes to devices.
