How do I tell if I'm O/C'd
7 Aug 2010
Further to my previous posts regarding unsually slow boot up on my new system. I have done a clean install of windows 7 on a freshly formatted sata drive. My mew MBGigabyte Z68 and i5 CPS are taking over 5 minutes to boot up with only a anti virus and a cad program installed. My old Q6600 only too 2:40 seconds. I'm thinking that somehow I've messed up the overclock, all i did was install Windows then insert the gigabyte CD and press install all to install the drivers.
How can i tell if I'm O/C'd , obviously i'm a newb at this.
http://www.cpuid.com/softwares/cpu-z.html
Run that while running this, so it runs on the overclock speeds instead of idle speeds: http://www.mersenne.org/freesoft/
The overclock shouldn't be affecting boot times, CPU speeds hardly affects it overall actually. It's mostly the HDD that bottlenecks it. What motherboard and harddrive do you have?
EDIT: You already have a thread here: http://forums.overclockers.co.uk/showthread.php?t=18422402
Please keep it to one thread... no need to make more on the same topic.
Gigabyte Krypton Z68 M.B and Hitachi HDP725025GLA380 ATA hard drive. Just ran specy and it reports that my CPU is at stock core speed of 3300 Mhz, that's base speed isn't it?
Hi, yeah sorry for running two threads. So are those figures fine for an overclocked system or a standard install. I can call the tech boys in the morning as i don't want to change anything in case I invalidate my warranty.
All I need to know is have I somehow messed up the overclock from overclockers, if so I guess the techs will be able to get me back on track?
At the moment its hard to say until you run the prime to put the CPU under full load.
You can reload the overclock by popping into the BIOS and loading the saved profile which Ocuk would have saved.
realtemp I used. It gives a good temp readout, also it will tell you what speed your cpu is running at and what multiplier so you can see the load going on and off the CPU
