How do I test this adaptor brick
13 Jun 2007
Dorset
How can I test whether this is dead or alive, without testing it on another laptop?
If you get nothing from the barrel jack, be sure to check continuity from the mains plug to the input plug - unlikely that that would be the culprit, but only takes seconds.
Ok, I have a multimeter. Hopefully, someone with far more experience can tell me what is going on.
The cables to and from the adaptor have electric current/continuity. I tested the multimeter with a 9v battery (1st image) which is accurate.
I first tried testing the barrel plug in auto mode. It would only test the resistance. (2nd image)
I then put the settings to Voltage only. (3rd image) The image shows a reading of 00.18 but honestly, it had various readings including much much higher, none of them the 20.0v output stated on the adaptor
Is this brick dead or am I not using the meter correctly
OK. I have discovered the fault.
When I connect the Cloverleaf socket to the adaptor it blows the mains plug 5A fuse.
So I am guessing there is a problem with the adaptor itself?
