So let's set the scene. I recently managed to acquire a number of fans for my phantom case after contacting NZXT' Support Centre. I ended up contacting them in the first instance because it seems that the orange FZ LED fans have been discontinued making it difficult to source them. After a week I received a parcel from them containing a number of reconditioned orange LED fans. All these fans seem to be the older airflow models of the LED variety. Suffice to say I was pleased.
Cut to yesterday and my good luck has come to an end. I decided to install all my new fans. I hooked them all up to the appropriate molex connectors and then powered up. Just one orange fan came on.
I turned the system off and then took a look at the wires and found the route of the problem. It appears that each LED fan has a 3 pin power cable and also a separate LED controller cable which is a 2 pin female connector. The Phantom original case that I own has a switch on the rear of the case, but this only has one male 2 pin connector. Suffice to say I can only plug one fan in at a time.
Now I've spent a lot of time digging around to find a solution to this problem, but so far I've found very little that helps. I don't particularly want to start rewiring my case and sort of hoped there was an actual solution out there.
What little I have found suggests that for other fans such as the BitFenix line, jumper cables are included to turn the fans permanently on or off, but these can also be attached to a controller of switch. I don't know if NZXT fans come with a jumper and the reconditioned ones I was sent certainly didn't seem to.
So as you can see I'm sort of stuck. If anyone has any input into this problem or has come across it before, please let me know. Any help is appreciated.
And yes I have already contacted the NZXT support centre again regarding this, but I don't expect an immediate response from them and I always find mutiple avenues of investigation turns up more.
Thanks again.
Thanks again.
