how do i (ubuntu) ???
6 Jan 2006
Newcastle
im wanting to customize Ubuntu to a specific detail basically so that a lot of the programs have been removed and that specific users only have access to the programs maybes background (change pic etc) and thats it...
ive removed the programs that i don't want and set up 2 groups admin and terminal users and thats all i want but i dont want terminal users to have options to services or systems etc how would i go about doing this (then i want to make an iso of the setup) and install on several other machines ive heard of alternate cd but i aint heard anything other than a customizable oem cd....
any help would be brilliant please
Have you looked in
System > Users and Groups?
If you click on a username and click Properties, under the prividges tab theres a list of things you can allow/disallow that user to do.
Having just taken a look I don't know if it will be enough, might be a good place to start though.
yeh thats like access to fax scanner etc (off the top of my head) ive done that and it has narrowed it down i just want rid of the system link though
If you're on about the top menus in Gnome, there should a be a Menu Configuration/Layout or something like that in System > Preferences which should let you remove program entries, or you can use XML files in a user's $HOME/.config/menus/ folder but that's trial and error and a bit of a pain.
You can't easily make ISOs which include your own custom settings (just packages really), post-install scripts for copying your configuration files over to the new machine should be OK. Imaging the whole hard disk would probably work as well, bit of a sledgehammer/nut scenario though.
well there all the same spc realy so it should be easy just a hunk of old hp's pentium 3 (dunno what mhz) with 256 ram same mobo the lot..... thats all
thanks ill have to give it a look
